How to Edit non versioned SDE table
2168
08-09-2010 10:35 AM
JoseSanchez
Hi all
I am using SDE in Oracle 10G, and the account opening the table has erad and write privileges.
Is it possible to edit a SDE table that is not versioned in an editing session in Arc Map?
Is there any difference between the fact that the database is protected or public?
derekswingley1
Yes, you can edit without versioning your data, see:  http://help.arcgis.com/en/arcgisserver/10.0/help/arcgis_server_dotnet_help/index.html#//0093000015zv...
And yes, version privileges (I'm assuming that's what you mean since you're asking about 'public' and 'protected') matter, see:  http://help.arcgis.com/en/arcgisserver/10.0/help/arcgis_server_dotnet_help/index.html#//009300001630...
