How to direct publish to specific Schema in SQL Server
1215
02-06-2014 08:57 AM
MichaelMezzanotte
  Is it possible using Active Directory authentication to steer published tables to a schema other than the schema of the AD account that is doing the publishing?  What we've seen so far is that it only works when a schema with the AD account name exists and it will place the tables in that schema.  Can these objects be "moved" to another schema and have the GIS metadata updated to reflect the new schema?
thanks for the time.
MarcoBoeringa
Maybe this thread:
Feature Names in SDE Geodatabase
and the comments therein of ESRI's Shannon Shields and others, can answer some of your questions.
MichaelMezzanotte
Thank you - I've been looking for that post for a long time!!!!
