How to delete SDE database in SQL server
4410
04-08-2010 09:53 PM
FaisalMasood
Based on SQL Server multiple spatial database model, I created SDE database (storing ArcSDE repository) using post installation setup. Afterwards, I did not create any other database for storing user defined spatial data.
Now I want to create another geodatabase based on SQL Server single spatial database model. This can be done by running post installation setup.
I would like to delete already created SDE database completely (based on SQL server multiple spatial database model and storing ArcSDE repository), but can�??t find any information. One idea is to delete it directly from database list using Microsoft SQL Server Management Studio, but not sure is it proper way.
I am using Micrsoft SQL Server 2005 and ArcGIS Server Enterprise 9.3
VinceAngelo
Esri Esteemed Contributor
Before deleting the database, delete the ArcSDE service it serves.  This should
be as simple as stopping the service and using 'sdeservice -o delete -i esri_sde'.
Once the service is gone, you can just detach the database and delete the datafiles.
- V
FaisalMasood
Thanks. it solved my problem
DavidWheelock
Works for me, too.
David Wheelock Application Specialist      [email protected]
Oklahoma Department of Agriculture, Food and Forestry
2800 North Lincoln Boulevard
Oklahoma City, OK 73105-4298
Phone: (405) 522-5477 FAX: (405) 522-3590
http://www.oda.state.ok.us
"We are usually convinced more easily by reasons we have found ourselves,
than by those which have occurred to others."
Pascal
ducksunlimited
- V
Can I just delete the sde database directly by right clicking the database, then delete? what's the difference from detaching the database then deleting the datafiles? thanks,
VinceAngelo
There is usually more than one way to accompish any task.  If you detach, you can toss
the files into an archive / burn them to DVD before deletion, for the times when the answer
to the question "Are you sure you want to delete?" Is "Yes, oops no - #%@^!"
- V
