How to cut holes from polygon?
3419
09-27-2011 04:41 AM
JinMa
I need to cut out several holes from a polygon.  How can I do it? I have Arc9.3. Thanks.
Robert_LeClair
Esri Esteemed Contributor
mohamedsoliman
Here are a few online resources:
http://kb.iu.edu/data/ancm.html
http://webhelp.esri.com/arcgisdesktop/9.3/index.cfm?id=490&pid=487&topicname=Common_polygon_editing_...
Good luck!
Robert LeClair
Esri-Denver
When you are splitting polygons, make sure your sketch cuts completely through the selected polygon. Turning on edge snapping often helps ensure that the cut operation is completed successfully.
In addition, you can use the topology tools to split polygons.
If you are working with representations and shape overrides
SamCoggins1
Erase tool in ArcToolbox
