How to convert Annotation to Line?
5033
06-22-2015 04:43 AM
StephenLam
I have some annotations and want to convert them into Line with rotated angle so I can present it in label feature in ArcMap. However I can only convert the annotation into "Polygon" without rotated labels...Please advice the correct way to do so, thank you!
The conversion steps are as follows,
  1. Right click on the annotation in Calalog
  2. Go to Export > To Shapefile (single)
  3. Provide the "Output Location" and "Output Feature Class"
  4. Click OK
  5. After conversion, the converted shape file will be automatically append on the layers inside the "Table Of Contents"
SepheFox
Have you tried using the Feature to Line tool?
SepheFox
