How to connect to a File GeoDB?
3766
08-20-2014 01:54 PM
DaveMartin1
This is my first time trying to use GDB data.  I ordinarily work with Personal Databases (.mdb's)  I just downloaded (and unzipped) a GDB  from my County.  There's data in it.  It's 72mb in size.
From within a Map Doc, when I Add Data, I can see the GDB.  But when I click on it, it says "Failed to connect to database"  I'm running ArcEditor 9.3
So...
Can I connect to a GDB from ArcEditor?
What do I need to do, to be able to load some data from my GDB?
Any help appreciated,
Dave
JoeFlannery
Honored Contributor
JoeFlannery
Honored Contributor
OwenEarley
Joe's link contains the answer. If your local county created the file geodatabase in a recent version of ArcGIS then the geodatabase version will not be readable.
You could ask your local county if they could create a 9.3 version of the geodatabase using this process:
arcgis 10.0 - How do you create 9.3 version of a geodatabase in ArcMap 10? - Geographic Information ...
