How to combine/mosaic rasters (geotiffs)
7090
03-03-2016 12:46 AM
UweSchmidt
Hej all,
I want to combine two georeferenced rasterfiles. One rasterfile should be in background, the ohter smaller image should lay over the background image. I've tried combine, composite, mosaic and other tools without success. When I used this methods I get only a one channel image. I want to combine to one image that have two channels that each present one of the input images, so that I can assign color ramp to overlap region like the screeshot below. I know I could export the map, but I need the combined image in same dimensions and projection like inputs for further processing with other software.
Any ideas how I can solve that?
Thanks in advance!
Uwe
AjitkumarBabar
Try Mosaic Tool, it worked for me.
similar Discussion - How to merge raster files in ArcGIS?
UweSchmidt
Same result like before. I only get a one channel image, so I can't change the color from the 'overlay' part, only from the hole image.
