How to Clip a raster with a shapefile??
14185
04-06-2011 02:21 AM
HelenaAsttrom
Hey,
I have problems with clipping a raster file using a shapefile. I've downloaded a dem-raster in tiff format and I changed it to arcgis grid (since I read somewhere that this should be done first). After this I've made a shapefile of a reservoir that I need to make a TIN for(polygon.shp).
After this I opened both in Arcmap. The clipping i tried to do with the following steps:
1. Spatial analyst-> options ( general tab: analysis mask= polygon shapefile, extent=" same layer as polygon shapefile", cell size="same layer as raster grid") -> OK
2. Spatial Analyst -> raster calculator. I clicked on my raster to enter it into the expression box. Then I clicked evaluate.
When I do this I get the following error message: " ERROR 010067: Error in executing grid expression"
What am I doing wrong? I would highly appreciate any help I can get!!
Regards,
Helena
MichaelStjernholm
Hi Helena
Use the Clip function in Data Management \ Raster \ Raster Processing !
If you have a feature class with several shapes you may select a shape and use that.
set the checkmark in "Clipping geometry"
You don't have to bother with environment settings execept if you have special requirements in "Raster storage"
See also my thread on Clip bug 16 - 32 bit
regards
Michael
HelenaAsttrom
Thank you! Problem solved 🙂
myname
here clip will help you clip raster by polygon in ArcGIS - YouTube
