How to change my data to raster?
754
02-21-2012 01:46 PM
TingLiang
I have a data, the type shown in ArcCatalog is raster dataset, but it is EDM. The problem is there is no file with the extension .edm, the extensions are .gdbindexes, .gdbtablx, and so on. So I can not convert my file to normal raster. What should I do?
I want to see the attribute of these data, what should I do?
Thank you.
PatrickTaurman
The .gdbindexes and .gdbtablx extensions are extensions used in a file geodatabase.  You say you can see the raster dataset in ArcCatalog?   It sounds like you have a file geodatabase raster dataset.  If you want to convert it to a different format, use the Copy Raster tool, and specify the format you desire, such as .tif.
Patrick
