How do you reclassify many raster from one folder ?
886
06-24-2014 09:56 AM
DEAF_PROBERT_68
Honored Contributor
I am trying to write a model builder and what I would like to take many rasters and reclassify them and then use the raster to polygon and then add the field and then calculate field.
Problem is that I use the Iterate Rasters ( don't know if it must have raster existed in geodatabase) and then add the name and use Parse Path and value to take each raster name for each polygon.
I have all the rasters in different folder ie: 2006, 2007,2008, 2009 etc and wanted to use model builder and modifty for each year as a separate file.
[ATTACH=CONFIG]34847[/ATTACH]
Here is the sample.
Any tips that I need to fix the problem ?
