How do I create a layer from selected polygons in the attribute table?
1436
08-24-2017 07:20 AM
BenScotting
Trying to do this in Arc 9.3.1.  Can't work out how to make it visible.
AdrianWelsh
MVP Honored Contributor
Hi Ben,
Where does the issue occur?
This article should walk you step-by-step through the process:
Creating a New Layer from Selected Features
And if not, here is a video with the same process (specifically for 9.3.1).
ArcMap - ArcGIS 9.3.1 - Creating Layer From Selected Features - YouTube
ChrisDonohue__GISP
If you want to create a new feature class of just the selected features in a feature class:
If you would instead like to create a Selection Layer:
ArcGIS Desktop Help 9.3 - Using selection layers
Chris Donohue, GISP
