How do I access and download OpenStreetMap data layers?
4610
10-18-2017 11:30 AM
AndresCastillo
I would like the layer to be in a format compatible with Arcmap/Pro.
Tags (1)
JoshuaBixby
MVP Esteemed Contributor
In terms of sharing a link, I recommend the GitHub page (Home · Esri/arcgis-osm-editor Wiki · GitHub  ) since it provides links to multiple versions of the download and not just 10.4
RickeyFight
Here is one way.
Trimble Data Marketplace
RickeyFight
I know mine works. I tried it last Friday. Just make sure you define an area. If not it will try to download the world.
AndresCastillo
Thanks, I will also try the ArcGIS Editor for OSM 10.4.x Desktop:
https://www.arcgis.com/home/item.html?id=c18d3d0d5c62465db60f89225fdd2698
JoshuaBixby
