Help with building script for multiple replacements in field
6653
21
12-07-2017 10:45 AM
MelissaTrascher
I have a field that has multiple names for the same company, for several companies.  I would like to build a script to replace the name for each company...
example: replace( [OPERATOR],"ANADARKO E & P ONSHORE LLC","ANADARKO")
FindReplace
ANADARKO E & P ONSHORE LLCANADARKO
ANADARKO E&P ONSHOREANADARKO
ANADARKO PETANADARKO
ANADARKO PET CORPANADARKO
ANADARKO PETROLEUM CORPORATIONANADARKO
CHESAPEAKE LIMITED PARTNERSHIPCHESAPEAKE
CHESAPEAKE OPERATING INC.CHESAPEAKE
CHESAPEAKE OPERATING INCORPORATEDCHESAPEAKE
CHESAPEAKE OPERATING, INC.CHESAPEAKE
CHESAPEAKE OPERG INCCHESAPEAKE
How can I build a single script for all replacements?
Thanks!
MelissaTrascher
def calc(field):
  if 'ANADARKO' in field:
    return 'ANADARKO'
  elif 'CHESAPEAKE' in field:
    return 'CHESAPEAKE'
OPERATOR=
calc( !OPERATOR!)
MelissaTrascher
Still failed. I am having no luck.
DanPatterson_Retired
it appears you are trying to calculate values for an 'OPERATOR' field... if so, you can't use values that are already in that field.  You need to make a new field of the same data type... say ... 'NEW_OP'... then you make that field active and use the calculator expression
cal(!NEW_OP!)
of course this assumes that your indentation is totally correct etc etc
JakeSkinner
Esri Esteemed Contributor
Melissa,
Can you upload a zipped sample of your data?
MelissaTrascher
I'm sorry, I'm new here - where do I go to upload data?
JakeSkinner
When replying click on Use Advanced Editor at the top right:
Then you will see the Attach option in the lower left hand corner:
MelissaTrascher
Thanks, I had to reply to original message to see the advanced option.
MelissaTrascher
Here is the data I am struggling with.
Did you try the suggestion https://community.esri.com/thread/206396-help-with-building-script-for-multiple-replacements-in-fiel... because your haven't clarified the name of the field you have the data in and whether or not you are trying to add this to a field of the correct type.  You calculator expression was incorrect as it was posted.
BTW, it appears to have been answered... so what was the solution?
MelissaTrascher
I did try it.  I added a text field named it NewOp, selected it, then ran field calc.  It didn't work.  Its time I took a scripting class... the basics are not working in my new job.
I didn't report that this was answered... unless it was by accident when trying to find the advanced editor. Ugh.
