Help: Converting polygon to raster with attribute table
993
04-23-2010 03:55 PM
JenniferMcLaughlin
Hi there - I'm able to sucessfully convert my polygon shapefile to a raster but I can't figure out how to carry the attribute table over? When I look at the product in ArcCatelog, the Geography choice is my only view option instead of "Table" as well?
Thanks for any help!!
RonaldBerger
Greetings,
If your polygon to raster output is a 8 bit single band dataset then you can build something called a raster attribute table. With this you might be able to join your tables in a way to get your information into the raster table.
Let me know if this helps.
Robert
