Grid Points
9138
6
04-08-2011 08:10 AM
CindyCarter-_Davis
Hi, I'm a self- taught ArcGIS user (10.0) and I would like to create grids of points. I tried to use the measured grid option, by turning the grid into a series of points, but when I try to ungroup them so I can just show the ones in my project area ArcGIS crashes.... any ideas? Thanks so much for the help!
michaelcollins1
It doesn't crash when I try it.
I'm not sure what you are trying to accomplish here. You could create a table of grid coordinates in excel, then use Arc catalog to import the table as a point shape file.
CindyCarter-_Davis
I guess I didn't explain myself very well. I am trying to overlay proposed shovel test locations (I'm an archaeologist) on a project area in 30 meter intervals. Normally, I just create points by hand, but this project area requires more than 2000 shovel tests... the measured grid shows what I need, but I can't seem to convert the graphic so that I can delete extraneous points, and only show the "dots" in my project area... I know that there is an easier way, but can't seem to find one other than creating each stp point by hand..
MelitaKennedy
Esri Notable Contributor
How about the Create Fishnet tool? It creates a polyline or polygon feature class, but there's an option to create label points. If you use the polyline option with create label points, you'll get a point feature class.
Melita
CindyCarter-_Davis
Melita,
Thanks so much, it worked great!!! You just saved e abut 8 hours of making dots
EricGriffis
Is there a tutorial of how to do this? No one in our GIS department seems to know how to do this. Thanks.
MelitaKennedy
I don't know if there's a tutorial. The Create Fishnet tool is a little complicated possibly because it's modeled after the similar command in ArcInfo workstation. There's a decent topic that has some pictures of what happens if you set a rotation for example.
How Create Fishnet works
You can build the fishnet in any coordinate system. Sometimes it's easier to build a lat/lon one while at other times, it's easier to build one based on the coordinate values of a projected coordinate system (like UTM). You need to have the spatial extent and  the "cell size" or distance between grid lines. Alternatively, you can have a lower left corner plus how many 'rows' and 'columns' you want. If you have the later, the tool will figure out the separation distance for you.
Note: If I remember correctly, the dataset created by the tool won't have a defined coordinate system, so you'll want to do that first with the Define Projection Tool.
Melita
