Georeference CAD data
1724
08-31-2010 02:21 PM
by Anonymous User
Not applicable
Original User: alnesbit
Hello all,
I'm using 9.3.1 ArcInfo.
Ok, I read how to georeference CAD data. I have been doing it that way for a while. But there has to be a better way...Anyone?
I read why I can't have more than 2 control points. And I understand that. But I'm having to open the dwg in CAD and plotting a pdf, then creating a tiff from the pdf. Then georeferencing the tiff in ArcMap to the aerial and then trying to get the CAD dwg at least close to that. Then recreating all of the data from the tiff into a geodatabase by manual editing. Then creating annotation from the CAD. Then going back and moving the annotation to where it should be.
So, why can't I have the option of a different kind of transformation with CAD data? Is it hard to program the software or something?
What do other people do when they have this problem? I finally got to a point where I would like a better way, but I don't think there is one. ugh.
Thanks for your ideas,
AnantThunuguntla
Hello all,
Hi Andrea,
If you would like to use more than 2 points for transformation ,you can use the Import from CAD tool to convert the CAD Drawing to a Geodatabase. You can then perform the desired transformations say Rubbersheeting on this data.
We allow only 2 point similarity transformations just to preserve the aspect ratio of the CAD dataset.
by Anonymous User
Not applicable
ideas website: https://c.na1.visual.force.com/apex/ideaView?id=0873000000087QpAAI
I don't want to preserve the aspect ratio of the CAD dataset, I want to match it to the aerial.
You're talking about the tool "Import from CAD" right? Have you tried to do it this way? It's horrible. I just did it and it created line, point, area. It didn't keep the layer names in the attribute table or the symbology the same as the CAD drawing. I don't know what is what.
so I guess the way I'm doing it is the only decent way as of right now. sigh
AnantThunuguntla
Sorry about the above suggestion. Can you try the Feature class to Feature class tool.
If this doesn't help, can you call up tech support, they should be able to help you out.
