Geometry Network - Network build errors table
2541
12-03-2012 10:01 PM
AleksandarStojanov
I am trying to resolve errors in Network build errors table in File Geodatabase. My question is, where can I read feature class ID? I create join by Object ID, but I can not recognize Class ID of the class.
Thank you,
Aleksandar
CraigGillgrass
Aleksandar,
There is a command on the Geometric Network Editing toolbar called Network Build Errors, it will read the table and select all the features listed in it.
If you want to do this yourself, what release of ArcGIS are you using?
AleksandarStojanov
Craig,
I use version 10.0. I find the solution:
arcpy.describe("feature class name").DSID
Aleksandar
CraigGillgrass
Craig,
Aleksandar
At 10.1, we also added a button next to the feature class name to display it's ID to make this easier to access.
