Geographic Transformation Issue
1265
10-03-2011 12:31 PM
SantoshPanda
I want to Project a raster map which is in 'UTM_NAD27_Z4' projection to 'Albers Conical Equal Area, Datum WGS 84' projection.
The 'Project Raster' tool in ArcMap 10 gives me 30 different options for Geographic Transformation.
What Geographic Transformation should I use?
I would appreciate any help or info.
Thank you,
Santosh
PatrickTaurman
Depends on where your data is located.  Here is some helpful links:
http://blogs.esri.com/Support/blogs/mappingcenter/archive/2009/05/06/About-geographic-transformation...
http://webhelp.esri.com/arcgisdesktop/9.3/pdf/geographic_transformations.pdf
The second link has a list of all the transformations, and the areas of use.
Patrick
SantoshPanda
HI Patrick,
Thank you for the weblinks. I appreciate your help and time.
Santosh
