Geodatabase viewer role
1176
03-14-2019 07:02 AM
NajwanAlarashi
Can i put rules of views on single feature class in a geodatabase on oracle
For example i have road with 2 subtypes  Highway and Local
Can i set rule for users to see only highways in thier maps
Wht best to do that
Jared_Motuz
If this explicitly regards permissions, then no, you cannot designate view/edit permissions based on attributes within a feature class. If you are trying to manipulate how the map displays the features then your best bet would be to configuring symbology options and/or definition queries for the layer based on these values.
Although, if this is for permissions reasons, you could utilize database views and designate these only pull records that follow your attribute specifications.
NajwanAlarashi
Thanks Jared
My purpose i want viewer user be able add layer from Geodatabase and only see certain features on that layer
(ex; he can see only highways whenever he add the road layer)
I wana do it on server side not map side
Asrujit_SenGupta
As Jared suggested, create a View with required features and share with the users.
