Geodatabase Toolset (GDBT) for ArcGIS v.10
17396
37
07-19-2010 11:24 AM
RachelBrowne
I heard a rumour at the ESRI International conference last week that there is no Geodatabase Toolset for V.10.
Could ESRI please confirm this and if this is indeed the case, how can we get this reinstated for the new version?
This is a toolset that we depend upon in our everyday management of SDE and if it is not available will significantly impact upon our plans to upgrade!!!!!
DerekLaw
Esri Esteemed Contributor
Hi there,
You heard correctly. At this time, there is no GDBT release for ArcGIS 10. Please note that the GDBT has always been an unsupported developer sample.
... how can we get this reinstated for the new version?
I suggest that you vote for this functionality on the ESRI Ideas.com site.
It has already been posted (in several forms) as an enhancement request:
1. Give me a GUI for ArcSDE
2. SDE Dashboard
3. Merge GDBT, MXDPERFSTAT, GDBDesigner, GDBDiagrammer, GDBReporter into ONE extension
FYI: one of Jack's ESRI UC preconference questions addressed the GDBT
Q: Will the geodatabase toolset become part of core ArcGIS Desktop?
Hope this helps,
JoeBorgione
Hey Derek- your link sends me to a place called salesforce.com; is this where we need to go and then sign up for a free 30 day trial?  Seems kind of odd...
That should just about do it....
MelitaKennedy
Esri Notable Contributor
I had the same problem when the Ideas site was first opened. Try http://ideas.arcgis.com instead.
Melita
MichaelHogan
Joe,
The links have been fixed to the right location on the Ideas Site.
Thanks
DerekLaw
Melita, Crystal, & Mike - Thanks to all of you for correcting my links!!!
JasonHoward
Seriously.  Why not just support this tool?  It's utility to the user community is obvious.
OvidioRivero
Jack answered this and I hope they stick to it:
Q & A
Data Management, Geodatabase
Yes. This functionality will become a part of ArcGIS. There is an ongoing development project to do this at the next release after ArcGIS 10.
In the ideas site they mention merging MXDPERFSTAT with this. I disagree MXDPERFSTAT has proven to be notoriusly unreliable to us in a key function we used to perform with GDB toolset in ArcGIS 9.2. That is the timing of fetching and drawing of features.  This fuinctionality was taken of GDBTOOLSET in 9.3.
AndrewRudin
By next release he means 10.1 right? not 11?
Thanks for the info.
Hi there,
2. SDE Dashboard
Hope this helps,
DerekLaw
Hi Andrew,
I can't comment on this because it is still early in the development cycle for the next ArcGIS release.
We just released ArcGIS 10.
Hope this helps,
