Geodatabase, changing projections.
1232
09-05-2012 12:37 PM
WilliamBassett
Geodatabase arriving from outside source, will I be able to change the Coordinate system, projection, and datum??
from what I remember its an easy fix...or am I thinking of something else.
JoeBorgione
As long as you know the projection parameters of the incoming data, you can project it into whatever you need it in.
That should just about do it....
