Geocoding Quite Slow and Stalling with Some Datasets
761
11-15-2012 01:17 PM
JustinSmith
Hello,
First I will explain how I created my compiled geocoder:
1) Created a Main locator with locator style General - Single Field, use the address point feature class as a primary table together with the KeyField alias name with the exact address field.  I use Spelling Sensitivity 100, Min Candidate Score 100, and Min Match Score 100 for Address Locator Properties.  (I have also tried different values)
2) Created a theoretical locator with locator style US Address - Dual Ranges, use a road network feature class as a primary table with From Left ,To Left, From Right, To Right, Street Name, Suffix Type, and Suffix Direction having alias names LEFT_FROM_ADDR, LEFT_TO_ADDR, RIGHT_FROM_ADDR, RIGHT_TO_ADDR, NAME, STREET_TYPE, AND OCTANT respectively. I use Spelling Sensitivity 65, Min Candidate Score 30, and Min Match Score 50, as well as Connectors: & @ l and for Address Locator Properties. I also have Side Offset: 11m and End Offset 10%.
3) I use both of the above with 1 being my priority.
When I attempt to geocode a table of 27490 records only approximately 3000 were done 16 hours later.  When I break that dataset up into quadrants I have had no difficulty with geocoding datasets with 4645 and 5095 records.  They are done in about 5 minutes.  I have a dataset with 5575 records that takes about 25 minutes longer, sometimes stalling at certain points in the process.  The fourth dataset with 6961 records does not work.  I have tried several times sometimes lowering some of the locator properties, etc; and it just will not work.  I have a feeling that same data is what is not allowing the the entire dataset to not work.
We do have access to another geocoder that consists of a main geocoder using US Address - Single House, an apartment locator, an alias locator, and Intersection locator.  This geocoder seems to have no difficulty, taking 15-20 minutes for the enitre dataset.  I cannot speak on the accuracy however.  As you can see I am very curious what is so wrong with the one I have created.  What is missing?  Is there an issue with using a point feature class and a polyline feature class together?
Any advice would be appreciated.
Justin
