Geocoding by intersections?
2848
11-25-2011 11:10 AM
JessicaChan1
Hi, I was wondering if there's anyway to geocode a whole list of intersections?
JoeBorgione
You can, the data just needs to be in a form that is consistent with the intersection that your locator uses.  Typically "&" "and" are the defaults.  So if your data looks like 'Elm St & 2nd Ave' or '33rd and 3rd' you will be good to go.  If your data is set up a little differently like 'Main St - Center St', you have two choices; change your address data to match your locator or change your locator to match your data.
