GDBT to ArcGIS 10.1?
12114
23
04-26-2013 12:32 PM
ChrisQuick
Will there be a new version of this for ArcGIS 10.1?  If not, does anyone know if the 10.0 version still works with 10.1?
CSQ
RexRobichaux3
Hello Joshua,
 Sorry to bring up an old thread but I was wondering what the SQL query of the states or state lineages table you ran against the GDB was to generate the WIL_sde_states.txt parse file? Thanks!
-Rex
JoshuaBixby
MVP Esteemed Contributor
We use Oracle user-schema geodatabases, so you have to define the schema geodatabase of interest.  My SQL file I use contains the following:
SET ECHO OFF
SET FEEDBACK OFF
SET LINESIZE 240
SET PAGESIZE 1500
SET TRIMSPOOL ON
COLUMN state           FORMAT a10 HEADING 'STATE'
COLUMN parent          FORMAT a10 HEADING 'PARENT'
COLUMN version         FORMAT a50 HEADING 'VERSION'
COLUMN lineage         FORMAT a10 HEADING 'LINEAGE'
DEFINE SDE = (name of user-schema geodatabase)
SELECT TO_CHAR(st.state_id) AS state
      ,TO_CHAR(st.parent_state_id) AS parent
       ,vr.name AS version
       ,TO_CHAR(st.lineage_name) AS lineage
 from &SDE..states st
 LEFT JOIN &SDE..versions vr
 ON st.state_id = vr.state_id
 ORDER BY st.state_id;
ShaunConway
Anybody want to give me direction of viewing the current state of the database in 10.2?
Shaun
AsrujitSengupta
For all those looking to use the GDBT with the recent releases of ArcGIS Desktop:
Using our favourite GDBT toolset with Desktop 10.1 or later release
