GDBT for ArcGIS 10 errors
2285
02-08-2011 11:33 AM
YimanSong
I'm getting the following errors when I try to use the Geodatabase Toolset (GDBT) for ArcGIS 10. Please see attached screenshot for more detail.
SpatialIndexView Error
License
VersioningSchematicVB
Does anyone have a solution for this issue?
JohnMeza
I suggest starting with the licensing issue.
What level of ArcGIS Desktop licensing are you using?
What type of Geodatabase are you connecting to (File GDB, ArcSDE GDB, etc.)?
Do you have any problems connecting to the GDB with ArcCatalog?
YimanSong
I'm testing with ArcEditor Single Use, connecting to a SQL Server 2005 GDB
YimanSong
No problem connecting to the GDB
deleted-user-zpcJw1u0IXiO
I'm having the same problem. Any ideas?
YimanSong
License issue. Although it's not mentioned, apparently it works well when I use ArcInfo.
