from xy coordinates to feature class
3533
10-03-2019 03:44 AM
SrinivasaRao1
I have XY Coordinates in xls and I want to convert these in feature class layers.
I tried by using display XY data in ArcGIS data and ArcGIS pro but I am getting an error.
ERROR 000308  Invalid field type
Please review and let me know how to resolve this issue
DanPatterson_Retired
the degree sign, I hope, is purely for display... otherwise the values are not numbers but text
Excel To Table—Conversion toolbox | ArcGIS Desktop after you clean up the excel file
and
XY Table To Point—Data Management toolbox | ArcGIS Desktop or
Make XY Event Layer—Data Management toolbox | ArcGIS Desktop
SrinivasaRao1
Hi, Sorry to say.. it couldn't work
JakeSkinner
Esri Esteemed Contributor
Hi Udaya,
I believe Dan was correct that the degree sign is causing the issue.  I removed the degree sign, and then executed the Excel to Table tool.  I was then able to convert the geodatabase table to point data.  Attached is the Excel table.
