FROM XML TO SDE
1224
11-22-2011 01:40 AM
RionaParumasur
Hi
Is there a way to convert a metadata xml file to sde using command line functions. I have managed to import the xml file into sde using arctoolbox but I am looking for an automated process. I have not come across any sdexml commands that allows for this.
Any assistance will be appreciated.
VinceAngelo
Esri Esteemed Contributor
Only ArcGIS supports the XML data generated by ArcGIS.  You can use Python tools as a
command-line loading option.
- V
