format coomand in ArcGIS 10-VB
1501
07-28-2011 11:25 PM
PoovalingaGanesh
I used "Format"command in Field Calculator in ArcGIS.9.x for formating Feild values.
Example: APN VALUES- 125
             APN VALUES- 12
I can format by using follwing structure
1) format([APN],"0000") = result will be "0125"
2) format([APN],"0000") = result will be "0012"
similaraly i  followed and calculated.
But in ArcGIS 10.0 not able to calculate. Please let me know how to use the "format" command.
thanks
Ganesh
BartBoute
             APN VALUES- 12
thanks
Ganesh
Hi Ganesh,
We have exactly the same problem here. A good working VB-function in ArcGIS 9.3.1 can't be used in ArcGIS 10, because the FORMAT function isn't supported anymore in AG10's field calculator.
Please let me know if someone solved the problem.
Bart Boute
BELGIUM
IABG_mbHIABG_mbH
Hello ESRI,
I have the same problem. Is there a solution in the meantime?
Jörg
BartBoute
Hello,
After a long search I found out that the answer is ZFILL in Python. Open the Field Calculator and choose parser: Python (and not VB Script)
Example 1
TERRID: OSK01
SZONE: A1
BPNR: 1
RESULT: OSK01A1001
Example 2
TERRID: OSK01
SZONE: X
BPNR: 1
RESULT: OSK01X0001
Calculation (Python)
!TERRID! + (!SZONE! .ljust( 2, '0' )) + (str(!BPNR!).zfill(3))
Can ESRI please give us a list of functions simular to FORMAT, that don't exist anymore in ArcGIS10, with the according function in Python?
Greetings :cool:,
Bart from Belgium
IABG_mbHIABG_mbH
Bart from Belgium, thank you very much!
The solution works beautifuly.
Jörg
ratnakartini
             APN VALUES- 12
thanks
Ganesh
Mr Ganesh i have the answer, hope it can help u and others outside...
Example:
BP_TEXT: 1
RESULT: 001
!BP_TEXT! .rjust(3,'0')
Have a nice day....
Ratna, Putrajaya.
