follow up query layer question
1125
03-15-2012 10:37 AM
maxsteinbrenner
so i am liking query layers a lot so far in playing with them!
my current question regards how keep the order i specify for the fields.
here is a query i am working with as an example:
SELECT sde2.sde.STREETCL_ARC.OBJECTID, sde2.sde.STREETCL_ARC.Shape, sde2.sde.STREETCL_ARC.SEG_ID, LTRIM(sde2.sde.STREETCL_ARC.PRE_DIR +' ' + sde2.sde.STREETCL_ARC.ST_NAME +' ' + sde2.sde.STREETCL_ARC.ST_TYPE) AS STREETNAME, sde2.sde.STREETCL_ARC.ST_CODE, sde2.sde.STREETCL_ARC.ONEWAY, sde2.sde.STREETCL_ARC.CLASS, sde2.sde.BIKE_NETWORK_TBL_NEW.TYPE FROM sde2.sde.STREETCL_ARC  RIGHT OUTER JOIN sde2.sde.BIKE_NETWORK_TBL_NEW ON sde2.sde.STREETCL_ARC.seg_id = sde2.sde.BIKE_NETWORK_TBL_NEW.SEG_ID
this makes a nice query layer with all the info i want HOWEVER if you notice i concatinate the field STREETNAME from a few fields. whenever the query layer is displayed this field shows up last. is there anyway to preserve the order i specify above (keep STREETNAME as the 4th column between SEG_ID and ST_CODE)?
thanks,
max
VinceAngelo
Esri Esteemed Contributor
I doubt the query code does any re-ordering of the SQL expression...
Which RDBMS are you using?
What happens when you issue the same SQL as a command at the SQL prompt?
- V
BTW: If you include your SQL in multi-line format, you'll probably get more folks to read it:
VinceAngelo
- V
maxsteinbrenner
hmmm, i can't get it to replicate the problem again this morning...
probably user error.
thanks again for your help, and the tip on proper sql query code indentation.
max
