find polygon corner coordinates
13160
02-06-2013 03:43 PM
CamW
I am trying to get the coordinates of each node of the polygon I create. I would like the attribute table to display the name of the polygon (ex. address) and then the coordinates of the nodes (ex. nodeA= Ax and Ay, NodeB Bx and By, NodeC Cx and Cy, NodeD Dx and Dy) is there a easy way to create all the needed polygons and then have the coordiends of the nodes displayed in the attribute table?
any help would be great!!
DanLee
by Esri Regular Contributor
Try the following:
1. Run Feature Vertices To Points tool on your polygons using the ALL option to get all vertices (if this is what you meant by "nodes").
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00170000003p000000
2. Run Add XY Coordinates tool on the vertices.
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Add_XY_Coordinates/001700000032000000/
Does that help?
