Field Calculator
13810
14
05-18-2016 06:09 AM
LianaSmith
I need to exclude all values that contain any letter from one of the fields. Basically only integers should be left. What code (Python/VB) do I have to put in field calculator for that?
Thanks!!!
LianaSmith
I removed space and got this error...
Then I tried to use single quotes like you wrote and got this:
DanPatterson_Retired
The following works as a field calculator expression in Pro and also in ArcMap.  Check the details
LianaSmith
Thank you !
TedKowal
Honored Contributor
LOL  I just got back to the office....  I only jumped in because it sounded like she only wanted to ignore those rows that had a character in it...   When using python, now, I avoid nulls and put an empty/blank/unused code  filter and delete in a two step process since I do not trust finding nulls yet in python.
Liana  I am happy you got it worked out!  That's all the matters!
LarryStout
Liana,
Using Python, the Codeblock (Pre-logic Script Code) would be:
def result(value):
    import re
    return ""  if re.search("[a-zA-Z]", value) else value
And the calculation would be:
result( !<FIELD_NAME>! )
Be careful overwriting the same field.  You can't undo it unless you start an edit session first.
Larry
