Field Calculator syntax vb calculating slope percentage
3072
02-18-2014 07:24 AM
DanaVan_Horn
I am attempting to calculate the slope of sewer lines. I am apparently missing some fundamentals of vb to get the syntax correct. I have fields:
From_Invert
To_Invert
Length (calculated)
The mathematical equation (rise/run) should be something like this:
(([From_Invert] -[To_Invert])/[Length])*100
I can't get it to fly in the field calculator. Any help would be greatly appreciated.
Regards,
Dana
RobertBorchert
Honored Contributor
I just use the simple   Slope= RISE/RUN
and multiply that times 100 to get a %
RISE = change in elevation
RUN = Distance
So what your doing looks right.
What is the attribute you are trying to do it in?  It should be a double precision.  If it is a long or short integer or may not work.
From_Invert
To_Invert
Length (calculated)
Regards,
Dana
DanaVan_Horn
Robert,
Thank you for your prompt reply. All of the fields are doubles.
I have attached a screen shot of the error I get when running the field calculator with the exact formula from my original post.
Thanks again,
Dana
RobertBorchert
Honored Contributor
I will assume your Invert values are your elevations.
Are they also a double or integer?  As well as your length field
Have you verified that all the Invert and length fields have values.
Try this
((abs([From_Invert] -[To_Invert]))/[Length])*100
Select just one feature in your table and run it on just that.
For length are you using the shape length or a calculated length.
If you still get the error run it again but instead of using shapelenght put in some number like 150
Robert,
Thanks again,
Dana
DanaVan_Horn
Robert,
I ran it on one and it worked. I found a sneaky null value in the elevation fields! Thank you for all of your help talking me through this.Probably the easiest problem you've helped with today 🙂
Thanks again!!!
Dana
RobertBorchert
Honored Contributor
Null value would do it.  Glad it worked out for you.
Robert,
Thanks again!!!
Dana
