Field Calculator Format Function
3275
06-24-2013 07:40 AM
OleksandrChubatyy
Hi
Format function in VB returns a type mismatch error.
The expression I am trying to execute is like this: Date_Str_Field = Format("06/24/2013", "dd-mm-yyyy").
Does not ArcMAp 10.1 support this function anymore?
Thanks
RichardFairhurst
Hi
Thanks
Format is a VBA function, not a VB Script function and is no longer supported by ArcMap 10.1.  VB script has a FormatDateTime function, but if the format does not match your regional settings, it is not at all easy to force the date into a custom format.  You basically have to write all of the parsing and formatting steps yourself for each date component, which is tedious.
Python should be something like:
import datetime
Date_Str_Field = datetime.datetime.strptime('06/24/2013', '%m/%d/%Y').date().strftime('%d-%m-%Y')
RichardFairhurst
Hi
Thanks
import datetime
