field calculator failure during processing in ArcMap error 000732
7641
7
09-20-2017 04:52 PM
ManuSharma1
I am facing  problem while running field calculator. I am using ArcMap 10.3.1. Join data from .CSV  to feature class. Every time it says data-sets does not exist or is not supported. https://community.esri.com/community/gis/managing-data?sr=search&searchId=fcc9a741-4925-4910-b6e8-9a...
JayantaPoddar
MVP Alum
Hi Manu,
The Join has to be permanent in order to execute Field Calculator. After joining the CSV to the Feature Class, export the Feature Class to a new Feature Class. The new Feature Class will also have the fields that were added from the CSV. Now, you should be able to execute Field Calculator in the new Feature Class (if the expression is correct).
Think Location
DanPatterson_Retired
The join has to be made permanent by saving to a new featureclass/shapefile.  You are attempting to do a calculation on a field in the csv table that you joined to the destination featureclass.  That isn't supported.  You can add a new field in the featureclass and do the calculation there using fields in the join table, but it is just better to save the results of the join, then do the work.
ManuSharma1
Thank you Dan,
I am going on copied feature class from different GDB. I am doing on Desktop GUI. No I am attempting to do calculation on new feature class field.
and the file is save on the desktop? don't.
Or... why don't you bring in the featureclass to your gdb... perhaps you don't have read/write access to that file in its current location.
ManuSharma1
I also kept feature class in GDB also and I have full R/W access. Any how its not executing.  I notice one thing while digging into Read write. Every time my folder became read only if I remove it (Read Only).
JayantaPoddar
MVP Alum
Hi Manu,
Think Location
