Field Calculation Question
1787
6
02-13-2013 07:57 AM
RyanHinesley
I have a name field attributed with a string that has a hyphen in the middle...
'text1... - text2...'
I want to use the field calculator to calculate another field based on everything to the right of the hyphen, excluding the hyphen and everything to the left so the result will look like this...
'text2...'
Note that the number of characters for text1 and text2 is variable throughout the feature class so the RIGHT and LEFT functions will not work. Any ideas without having to revert to a python script?
AnthonyGiles
Honored Contributor
Ryan,
Use an expression in the calculate field similar to :
Left of -
left([fieldname],instr([fieldname],"-")-1)
Right of -
Mid([fieldname],instr([fieldname],"-"),len([fieldname] - instr([fieldname],"-")
Or
Right([fieldname],len([fieldname] - instr([fieldname],"-"))
the instr function gives the position of a text string within another, and the left function extracts a string from another one, as does mid & right
Regards
Anthony
AnthonyGiles
Honored Contributor
Ryan,
Left of -
Right of -
Or
Regards
Anthony
RyanHinesley
Worked perfectly. Thanks so much.
Ryan
AnthonyGiles
Honored Contributor
Ryan,
Glad it worked, please don't forget to mark the post as answered,
Regards
Anthony
StewartGalloway
Anthony,
Can a version of your code help me to switch names within a field?  From "Smith, John" to "John Smith".
thanks.
Stew
DanPatterson_Retired
" ".join(a.split(", ").__reversed__())
where 'a' can be substituted with !YourFieldName!
use the python parser of course.
StewartGalloway
wow, thanks Dan.
