Field Calculate taking hours to run on less than 20000 feature?
2338
7
02-12-2025 11:17 AM
Labels (2)
amarcz_cc
Hello,
I am running an arcade script on my Building Footprint Layer that takes all the points (Addresses) within, and concatenates them into a string and puts the values into a field. (see below)
However, this particular script is taking hours to run?
Data is within the same sde, in a SQL database, working in ArcPro 3.3
// Retrieve the ADDRESS feature set
var address_fc = FeatureSetByName($datastore, "DBO.MasterAddress", ['Address_Full', 'AddressType'], true);
// Initialize a string to store the Address_Full values
var address_string = "";
// Loop through the addresses and check if they are within the current building polygon
for (var addr in address_fc) {
    // Check if the address is within the current building polygon and has AddressType = "Address"
    if (Within(addr, $feature) && addr.AddressType == "Address") {
        // If this is not the first address, add a comma separator
        if (address_string != "") {
            address_string += ", ";  // Add comma separator
        // Concatenate the address to the address_string
        address_string += addr.Address_Full;
// Return the collected addresses as a comma-separated string
return address_string;
2 Solutions
CodyPatterson
MVP Regular Contributor
Hey @amarcz_cc
This could be because you're filtering through all of your addresses while also making calls to the Within function, once done, it creates a new string each time, your run time for this would be O(N * M + N * K) which is quite large if speaking in asymptotic terms.
Consider this program here:
var address_fc = Intersects(FeatureSetByName($datastore, "DBO.MasterAddress", ['Address_Full', 'AddressType'], true), $feature);
var address_list = [];
    if (addr.AddressType == "Address") {
        address_list.Push(addr.Address_Full);
return Concatenate(address_list, ", ");
The main differences is that there's a checking of only the relevant addresses with intersects, and within may run per-iteration, something that could take forever. If I did this correctly and get the growth correctly, this is O(N + B * K), which is N number of addresses + B number of filtered intersecting addresses, finally multiplied by K concatenation.
Cody
KenBuja
MVP Esteemed Contributor
That line should be
Push(address_list, addr.Address_Full)
CodyPatterson
Hey @amarcz_cc
Cody
amarcz_cc
Thank you for the explanation @CodyPatterson. The code validates, but I am getting the error
ERROR 002717: Invalid Arcade expression, Arcade error: Integer index expected, Script line: 7
when attempting to run it. Any further help is apprecaited.
KenBuja
That line should be
CodyPatterson
Hey @KenBuja
Great catch! Switching between too many programming languages has its quirks!
Cody
MichaelVolz
So how long does it now take for your updated script to run?
amarcz_cc
Well, not sure what happened. Ran for 1.5 hours and got the dreaded 9999 Error.. so I am attempting to run again.
The Error is due to the array exceeding the character count of the field on some buildings, so I am doing going in smaller batches and will manually edit the features or the field to reflect the correct address.
amarcz_cc
Thank you @CodyPatterson & @KenBuja for the assistance! Is there a way to add something that will return a null value if the Building Footprint doesn't have an address on it? Or is that already built in?
