Field Calculate taking hours to run on less than 20000 feature?
1147
7
02-12-2025 11:17 AM
Labels (2)
Amarz
I am running an arcade script on my Building Footprint Layer that takes all the points (Addresses) within, and concatenates them into a string and puts the values into a field. (see below)
However, this particular script is taking hours to run?
Data is within the same sde, in a SQL database, working in ArcPro 3.3
// Retrieve the ADDRESS feature set
var address_fc = FeatureSetByName($datastore, "DBO.MasterAddress", ['Address_Full', 'AddressType'], true);
// Initialize a string to store the Address_Full values
var address_string = "";
// Loop through the addresses and check if they are within the current building polygon
for (var addr in address_fc) {
    // Check if the address is within the current building polygon and has AddressType = "Address"
    if (Within(addr, $feature) && addr.AddressType == "Address") {
        // If this is not the first address, add a comma separator
        if (address_string != "") {
            address_string += ", ";  // Add comma separator
        // Concatenate the address to the address_string
        address_string += addr.Address_Full;
// Return the collected addresses as a comma-separated string
return address_string;
2 Solutions
CodyPatterson
MVP Regular Contributor
Hey @Amarz
This could be because you're filtering through all of your addresses while also making calls to the Within function, once done, it creates a new string each time, your run time for this would be O(N * M + N * K) which is quite large if speaking in asymptotic terms.
Consider this program here:
var address_fc = Intersects(FeatureSetByName($datastore, "DBO.MasterAddress", ['Address_Full', 'AddressType'], true), $feature);
var address_list = [];
    if (addr.AddressType == "Address") {
        address_list.Push(addr.Address_Full);
return Concatenate(address_list, ", ");
The main differences is that there's a checking of only the relevant addresses with intersects, and within may run per-iteration, something that could take forever. If I did this correctly and get the growth correctly, this is O(N + B * K), which is N number of addresses + B number of filtered intersecting addresses, finally multiplied by K concatenation.
Cody
KenBuja
That line should be
Push(address_list, addr.Address_Full)
CodyPatterson
Hey @Amarz
Cody
Amarz
Thank you for the explanation @CodyPatterson. The code validates, but I am getting the error
ERROR 002717: Invalid Arcade expression, Arcade error: Integer index expected, Script line: 7
when attempting to run it. Any further help is apprecaited.
KenBuja
That line should be
CodyPatterson
Hey @KenBuja
Great catch! Switching between too many programming languages has its quirks!
Cody
MichaelVolz
So how long does it now take for your updated script to run?
Amarz
Well, not sure what happened. Ran for 1.5 hours and got the dreaded 9999 Error.. so I am attempting to run again.
The Error is due to the array exceeding the character count of the field on some buildings, so I am doing going in smaller batches and will manually edit the features or the field to reflect the correct address.
Amarz
Thank you @CodyPatterson & @KenBuja for the assistance! Is there a way to add something that will return a null value if the Building Footprint doesn't have an address on it? Or is that already built in?
