FeatureClass registered but not visible
934
10-07-2025 05:24 AM
Labels (2)
SIT_AGSM_VERONA_SPAAGSM_VERONA
Hi all... I'm trying to create a new FeatureClass on a DB Postgresql 11.12 via ArcgisPro 3.0.6 but the geoprocessing says that the name already exists.
In the catalog pane I cannot see it but if I query the sde_table_registry table, that name is present.
It's present also in sde_layers and sde_geometry_columns but not in sde_column_registry neither in gdb_items.
I don't want to change the name because there are others apps that refers to that name.
How can I reset the system tables in order to permit to create the feature class? Or how can I make it visible in the catalog pane in order to delete and recreate it?
Someone can help me?
Thanks a lot!
Matteo
George_Thompson
Esri Notable Contributor
Sounds like you have an orphaned record.
I would try and create a blank table with the exact same name in the same schema (i.e. GIS / DATA / whatever you have). It does not need to have any records or the same fields, just a table. Then refresh the connection in Pro. If you see the "blank table" delete it. It should remove it from all the system tables.
I have seen this with ArcMap and ArcGIS Pro over the years.
--- George T.
George_Thompson
--- George T.
Thanks a lot, it worked! you saved my day!!
Matteo
George_Thompson
Glad to hear that worked!
Please mark my response as the solution so others can find it in the future.
--- George T.
