feature to polygons of a large data, getting topoengine error
1451
08-03-2016 09:42 PM
TilottamaGhosh
I have a big polyline dataset for which I want to create polygons. I have been trying to run the 'feature to polygon' tool but it keeps failing with a 'Topoengine error'. I have tried 'Check geometry' and 'Repair geometry' and the geometry looks okay. How can I successfully create the polygon from this line feature? Any advise?
Tilo
DanPatterson_Retired
try a smaller subset, it may be the number of features that you are trying to process
JayantaPoddar
Yup... this could be a case of 'Godzilla' dataset (features with too many vertices). Check the following link.
https://blogs.esri.com/esri/arcgis/2010/07/23/dicing-godzillas-features-with-too-many-vertices/
Think Location
