feature-linked annotation blank
894
05-27-2011 02:06 PM
JaninaBarnes
When I create annotation for a feature using 'Annotate Selected Feature', the source data shows up blank.  For instance, the expression for the annotation subtype I used is
[DIAMETER] & "" "& [Material] & " " & "COND NO" & [COND_NUM], so the annotation for this feature should have been 18" STL COND NO 304, but what actually showed up was  "  COND NO .
All of the source fields were entered, but the annotation still acts as if they were empty.
If I edit any source attribute, the annotation shows up correctly.  Then I can change the value back, and the annotation will be correct.  It's as if the data wasn't being read in when the annotation is created.  This happens for every feature I have tried in the feature class.  The database is stored in Oracle 10G, and I am running ArcGIS 9.3.1.
