Feature Class table reporting - value occurrence reporting
1297
10-18-2025 06:34 AM
cmartin_puc
anyone know of a simple way to report the following on an attribute table?
  • Field Names
    • List of values in the field
      • Number of occurrences of each value
Example:
  • Field Name: Phase Configuration
    • Yellow: 1764
    • Red: 851
    • Blue: 289
DanPatterson
MVP Esteemed Contributor
through model builder with a field iterator calling
Summary Statistics (Analysis)—ArcGIS Pro | Documentation with the "count" option
obviously, only for fields of Text type
Iterate Fields (ModelBuilder)—ArcGIS Pro | Documentation
Or if you want other statistics for interval/ratio data type fields, you could accommodate that as well
... sort of retired...
RobertCollins
Echoing the comment above from Dan that the Summary Statistics tool would probably be a good starting point.
The graphic on the documentation's help page shows a visual example of how it'd work for your table.
The tool will output a table, containing each unique value in the field and the count of how many times this value occurs.
Alternatively, if you wanted to give Python a go a workflow along the lines of the following might be suitable:
  • Set the path to your feature class
  • Identify field to summarise
  • Read the values
  • Count the occurrences
  • Output the results
There is a built in python module called "collections" and within this the "counter" class can be used to count the occurrences of items in a list or iterable.
D_Atkins
Quick and rough implementation; replace "table = poly_selection[0]" with a reference to your own table...
A short script to:
   1. Get the list of fields from a table,
   2. Iterate every row of the table (using da.SearchCursor)
   3. Use list and dictionary to collect
      3a. List of fields, dictionary of values, count of occurrences
      3b. Optionally, limit # of unique values to report.
   4. Prints results to the console.
import arcpy
### PREPROCESS FOR LIVING ATLAS
poly = "https://services2.arcgis.com/FiaPA4ga0iQKduv3/arcgis/rest/services/USA_Block_Groups_v1/FeatureServer/0"
poly_layer = arcpy.management.MakeFeatureLayer(poly, "Atlas Census Blocks LayerView")
poly_selection = arcpy.management.SelectLayerByAttribute(
    in_layer_or_view = poly_layer,
    where_clause     = "COUNTY = '173' And STATE = '37'"
### Unique Values, All Fields from Table:
## My Table...
## Get the List of Fields from My Table
fields = arcpy.ListFields(table)
## Empty Results:
fields_list    = []  # list
fields_summary = {}  # dictionary
## List of Fields, and a 'Summary' Results Dictionary
for field in fields:
    fields_list.append(field.name)
    fields_summary[field.name] = [field.type, field.length, {}]
print('Found', len(fields_summary), 'fields.')
## Now, try to Collect and Count values for every Field:
with arcpy.da.SearchCursor(table, fields_list) as sCursor:
    for row in sCursor:                             # for each row,
        for index,item in enumerate(fields_list):   # for each field
                value_dict = fields_summary[item][2]
                if len(value_dict) > 100:    ## limit number of unique_values to manage
                    value_dict['MORE VALUES'] = value_dict.get('MORE VALUES', 1) + 1
                else:
                    value_dict[row[index]] = value_dict.get(row[index], 1) + 1
## Print our results:
for key in fields_summary:
    print('Field:',key,'\n', fields_summary[key], '\n')
RhettZufelt
MVP Notable Contributor
Depends on how "simple" you want.
One simple way is to load into Pro/ArcMap and symbolize on the Phase Configuration field, then select Show Counts.
R_
