Try the Calculate Value tool.
Here are the parameters to use for the Calculate Value tool. For the purposes of the example, I am assuming the name of your input feature class model element is: "Input Point Feature".
Expression: GetPoint(r"%Input Point Feature%")
Code Block:
import arcpy
def GetPoint(fc):
pt = arcpy.da.SearchCursor(fc, "SHAPE@").next()[0]
return pt
Data Type: Point
Calculate Value always returns a text representation of the value; the Data Type parameter is used to tell the tool you connect the output to what the output is, in your case, a point geometry. So, if you use Data Type "Point", you should be able to connect the "Point" output to the Get Cell Value tool.
Set your feature class to be a precondition to your Calculate Value tool. This makes sure "Input Point Feature" variable is populated and ready to go when you run the Calculate Value tool.
Hope this helps you out.
