Feature Class Export Data to Shapefile Corruption
2143
08-28-2010 03:34 PM
TraceyHarris
I've a PGDB with Coded Value Domains and 2 subordinate Feature Classes.  When exporting a Feature Classe to a shapefile, those fields with coded values display the code versus the description.  Is there a solution that will result in the fields being populated with the description verus the code?   (I have changed the codes to mirror the descriptions; that change will affect future entries. The challenge is to effect change on the current records.
