Feature Class Containing Points and Multi-Points
2697
06-08-2015 03:09 PM
MichaelVolz
Esteemed Contributor
I have a Query Feature Class from a non-SDE Oracle 12c database that contains both points and multi-points.  Would anyone know if it is bad practice to have such a feature class as it has rendering issues (sporadic visibility at different pans and zooms) and does not work properly when queried in 3rd party GIS based software?
Is it possible to have a single vertex multi-point object?  I ask because loading the data into the feature class resulted in points with single vertices being point objects and points with multiple vertices being multi-point objects.
