Feature class bounding box is much bigger than XY extent?
3733
09-16-2015 07:43 AM
TuridBrox
I have a feature class where the XY extent (on the Feature Extent tab of the Feature Class properties) is set to a relatively small extent - max y 6 657 856 meters, min y 6 646 293 meters).
Yet, the Bounding Box for the feature class (on the Indexes tab of the Feature Class properties) is very large (max Y is 9 007 189 256 640 meters min Y is - 9 998 100 meters, probably the Maximum for this coordinate system - ETRS 1989, UTM zone 32N).
This seems to be impeding performance when editing. How can I tell the Feature class that the bounding box should be much smaller?
JakeSkinner
Esri Esteemed Contributor
Hi Turid,
You can recalculate, import, or manually set the feature extent of the feature class by right-clicking on it in the Catalog window > Properties > Feature Extent tab.  Ex:
CherieMoritz2
Hi Jake,
We see this frequently too.  The bounding box is much bigger than the feature extent.  We can fix it, but can you suggest a reason why it would be that way to begin with?
Cherie Moritz
Aiken County, SC
