Feature accounting of a versioned dataset served as a feature service
2314
09-01-2022 05:39 AM
AdewaleFalaye
I am trying to account for every change/edits in a versioned dataset that was published as a feature service. I have multiple editors making changes on the feature service and I need to be able to track, audit and manage all changes. Has anyone tried this or could point in the right direction please?
RobertKrisher
There are a few ways to achieve this. If you're looking for a manual / quality assurance type approach you can have your users perform their edits in versions and then your QA personnel can use the differences view to review changes before versions are posted.  You can learn more about this approach in this page in the online help .
Using the same workflow you can also programmatically inspect the edits in a version using either c#, python, or direct rest API calls to the differences endpoint of the version management service.
RobertKrisher
AdewaleFalaye
Thanks @RobertKrisher. I believe I found something I can work with here.
MarceloMarques
If you are using an Enterprise Geodatabase ( Oracle / SQL Server / PostgreSQL ) and the featureclasses and tables are registered as versioned then you can enable Editor Tracking and enable Geodatabase Archiving.
Enable editor tracking—ArcGIS Pro | Documentation
Enable archiving—ArcGIS Pro | Documentation
What is archiving?—ArcGIS Pro | Documentation
I hope this helps.
| Marcelo Marques | Esri Principal Product Engineer |
| Cloud & Database Administrator | OCP – Oracle Certified Professional |
| Esri | 380 New York St | Redlands, CA 92373 | USA |
| Esri Enterprise Mapping and Charting Databases Best Practices |
THE SCIENCE OF WHERE ®
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
AdewaleFalaye
Thanks @MarceloMarques. This is very helpful
