FDO Error: -2417483640 Validaing Network Topology
1268
12-29-2022 11:26 PM
Labels (2)
LucasGodedMoreno
Hi, this error appears when validating some parts of the map, it was after modifyin the terminal connections, but when I put them back as before, this error is not removing and it keeps coming out. Does anyone know a wa to fix it? Thanks a lot!
Edit operation failed: FDO error: -2147483640 [Topology_engine::query_from_to_junctions(): Topology entry (edge eid: 1261) not found.]
RobertKrisher
I recommend you log a case with support for this issue.
