FDO ERROR: 2147216117
5522
02-14-2012 01:39 PM
MCIHALWILTON
hI,
I am using ARCGIS 9.3.1 for desktop with oracle and ARcsde, when i am trying to export a shapefile to oracle through sde, getting following error: FDO ERROR: 2147216117, anyone please can guide what might be the issue?
Best Regards,
Mic
JonDeRose
Mic,
It has been some time since your post.  Not sure if you have already found a solution.  FDO Error -2147216117 references a network failure "FDO_E_SE_NET_FAILURE".  If this issue is still occurring please post some additional info on your testing and errors, thanks.
- Jon
PeteAtwood
Hi Jon,
I have been having this problem for some time now.  I am running Arc10 on both xp and windows 7 64bit, our server is windows 2003.  When trying to edit and save shapefiles on a network drive we keep getting the network error FDO error: -2147216117.  Also, when saving sometimes it saves the edits correctly then exits edit mode even if the user does not stop editing.  Annoying.  Any help is this matter would be greatly appreciated.
Pete
DanielleKreamer
I was getting the same error.  Refreshed SDE connection in catalog. Still got error.  So I just gave up on trying to save edits and closed the mxd and reopened it.  Started editing again and added info into table of a new shape and now am not having any problems saving edits.
