Fast Raster Pixel Access
2203
03-25-2011 09:15 AM
anthonybaker
I can read a tiff outside of ArcObjects in under a second.  In ArcObjects the same access is significantly slower (30 to 50 seconds).  Is there a fast way to access pixel values within ArcObjects?
DarylVan_Dyke
I recently struggled with something similar.  I ended up using GDAL.  GDAL works great, is fast, and has configs for a number of different raster formats.  I ended up deciding on using .IMG (the GDAL .IMG driver supports rasters >2 GB) and mixing in GDAL calls into my script.  Depending on your programming environment & language, there may be (probably is?) a GDAL API for you.
I just upgraded to 10, and saw a reference on one of the ArcGIS blogs indicating that GDAL is pre-configured in the ArcGIS Python 2.6 implementation.  I haven't messed around with that, and in the past have explicitly maintained a GDAL install on my ArcGIS Python 2.5.3 install.  It sounds like you aren't programming in python, though, and may already be aware of the GDAL option.
I don't look to make it complicated, but GDAL was 10 - 50 x faster.  Made the approach for feasible rather than infeasible...
