Failed to create feature dataset Arcgis 10.3
4511
03-13-2016 05:22 AM
VaidhyPanday
hi all,
i have installed arcgis 10.3 and connected with oracle with a direct connection.
i am able to create feature class and on top of that i am able to perform all  feature class operations.
but while creating a feature dataset it throws a error.and doesnt create feature dataset.
am i missing something in configuration ? !
UmakantJoglekar2
Hi Vaidhy Panday,
Can you right click on your connection (connection to panday) and paste the screen capture of options available?
Thank you!
VaidhyPanday
UmakantJoglekar2
Thank you for the screen capture!
This explains why you cannot create a feature dataset. You are working with an Oracle database with NO geodatabase in it. A feature class is nothing but a table with spatial column in it however feature dataset is a logical geodatabase entity which requires you to have geodatabase enabled in order to create/use feature dataset.
You can create feature classes in this Oracle database with SDO_GEOMETRY storage type (Oracle spatial) or ST_GEOMETRY storage type if you have added it using following tool:
Add the ST_Geometry type to an Oracle database—Help | ArcGIS for Desktop
However if you would like to take advantage of geodatabase functionalities like feature dataset, topology, geometric network, multi-user editing etc you will have to run 'Enable Enterprise Geodatabase' tool against this Oracle database:
Enable Enterprise Geodatabase—Help | ArcGIS for Desktop
You can read more about this here:
Set up a geodatabase in Oracle—Help | ArcGIS for Desktop
A quick tour of the geodatabase—ArcGIS Help | ArcGIS for Desktop
Hope this helps!
JayantaPoddar
Have you created an enterprise geodatabase in it?
Create Enterprise Geodatabase—Help | ArcGIS for Desktop
Think Location
VaidhyPanday
No,but i am able to create feature classes..
